If you have a way to do this please let me know. thanks for your help.
you can use windows 'print screen' function.
open the mpeg. go to the scene you want to make a .bmp of, and pause it. then press the 'print screen' button at the top right of your keyboard.
open ms paint. [go to your star menu>programs>accesories>paint.
go to file>new and press 'ctrl+v' [ or edit>paste]
then save the new file as .bmp and thats it. -
You can use SWBcapture or Hypercam...SWBcapture is free and VERY Easy to use. You can get both at download.com.
Virtual Dub will do it too. I've found this to be the easiest way. Just load your mpeg into vdub and move to the frame you want to make a bmp of and under "video" copy to clip board and past into whatever program you're going to edit it with.
What program to make menued DVD using multiple flv files
By rdfarr in forum Authoring (DVD)Replies: 4Last Post: 8th Mar 2011, 07:18 -
Anyone know of a good MP3 program to resize (make smaller) some files
By soulbug in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2011, 15:03 -
how do i insert a title frame (e.g. a mpeg, bmp or gif)
By eduardo0701 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2010, 09:20 -
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 17:09 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 22:32
