I need a DVD authoring program that will let me import MPEG2 files and AC3 audio files. I need something with basic menu creation and easy to set chapter points. Also, I need a program that will just mux my files together and not "check" them like Sonic's DVDIt PE does. Pinnacle Impression DVD Pro fit this bill PERFECTLY but even after applying the 2.21 patch for the pro version, it still crashes a LOT on my XP system and I'm fed up with it.
Any recommendations?
Scenarist comes with AC3 encoder.
DVD Workshop should have an AC3 encoder sometime in July, according to other postings on this forum./\/\ars /\/\ayhem -
I've had a boatload of trouble trying to get SpruceUp to accept an AC3 file.. Any pointers??
My audio source is captured in Adobe Premier.. I can output it via premier as a raw avi file, then run it through besweet to get the AC3 file, but SpruceUp will not take it...
Grrr..
And I wouldn't mind DVDit! encoding it for me if I could, at least, demo the software BEFORE I buy it (I bought MyDVD, and, for anyone but the novice user, it just does not hold up).. -
Originally Posted by marsmayhem
Anyone know if it's possible for VV3 to save the audio tracks seperate? I currently take the WAV into GoldWave and seperate the left and right channel. Can I eliminate goldwave and do that with VV3? -
A good craftsman has many (excellent) tools in his toolbox, not just one fancy swissknife...
/\/\ars /\/\ayhem
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 19:32 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Authoring Software that supports h.264
By sampalmer21 in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd Nov 2009, 09:17 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 06:53 -
Authoring/burning application that supports half-d1?
By sharper in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2007, 15:38
