Whenever i download avi movies the file size is pretty decent. After i convert them to mpg with TMPGEnc the file size doubles/tripples..
My question is, is there a way i can convert the avi to mpg with better compression. or mabey is there another program that will compress mpg's after i convert them from avi?
I ask this because the movies i download are around 400mb avi. And when i convert them, they are way to big to burn to vcd.. i need better compression. if anyone can help, i'd really appreciate it.
Thanks,
-nick.
sounds to me like your *.avi files are really in the divx format...mpeg4/divx gets an acceptable picture @ half the filesize usually.
so, you're out of luck in that respect for getting them to fit on one cd.
maybe if you cna find some 800/850mb cds you could fit your mpegs.
check under tools to the left for cut/join programs so that you can split yer mpeg onto two discs, or split your .avi and then convert to mpeg for two discs
THIS IS HARDCORE
Help: AVI compression using virtualdub
By stan101 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 21:55 -
2875 x 768 px mpg compression?
By pisosse in forum Video ConversionReplies: 5Last Post: 8th Jul 2009, 00:29 -
Help with AVI compression.
By breeze9 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2009, 02:06 -
ginormous avi (even after compression) What to do?
By hygieneboy in forum Authoring (VCD/SVCD)Replies: 6Last Post: 30th May 2008, 00:28 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
