when i am converting a file to vcd does a higher bitrate increase the quality if i am playing it in a DVD player? i would leave the resolution the same and only change the bitrate.
thanks for your help
Yes the higher the bitrate the higher the quality, of course the quality of the source is the overall limiting factor.
Note that if you use higher than standard bitrate than you are making an xvcd not a vcd and you will not be guaranteed compatiblility on all hardware players. -
VCD(NTSC):
res:352x240
video bitrate:1150kbps mpeg-1
audio bitrate:224kbps
Any other specs.and your file is a xvcd
http://www.vcdhelp.com/vcd.htm
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 11:17 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 22:50 -
H.264: higher video bitrates than suggested image size not working?
By FiD31 in forum ffmpegX general discussionReplies: 7Last Post: 23rd Jun 2007, 11:49
