I have a 1gb movie file for example... is there a way to put it in 700? THX!
Could you restate your question?
Are you looking to convert a 1Gig AVI to a 700Meg MPEG-2 or a 1Gig MPEG to a 700Meg MPEG? -
Filesize is directly proportional to bitrate. Regardless of what your source is, just convert it to the desired format and use a bitrate calculator to determine what bitrate to use to get the desired filesize. You can find a bitrate calculator in the tools section. Note that this only works for multipass vbr or cbr encoding modes. If you use anything else it is simply a matter or trial and error.
BTW, this issue is specifically convered in almost every single conversion guide. -
Is there away to limit the size of the movie using TMPGEnc?
Originally Posted by Solum
Or you can click settings > source range, and limit how much it does. (half at a time) to fit on 2 VCD's
Sqeezing the whole lot onto 1 CD, will give a bad quality movie.
USB hard drive size limit on LG DVX392H
By BaggyB in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th Dec 2010, 11:50 -
Would You Increase the Upload Size Limit?
By Soopafresh in forum FeedbackReplies: 2Last Post: 12th Jan 2010, 15:23 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 09:13 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
VDub/MOD cant limit my file size?!?!
By GangstaRap in forum Video ConversionReplies: 6Last Post: 29th May 2007, 04:36
