sorry fi this has been asked 100000000 times before. Anyways, it always says "file unsupported" when i use TMP to try and open an avi for conversion. i installed 3.11 and 4 codecs ( i think), but that still didn't resolve the problem. divx player ver. 2.0 will play the movie, but none of the converters will recognize it. how do i find/install the correct codecs, or whatever i need? thanks.
Use Virtualdub to convert to another codec like huffyuv, indeo5 or uncompressed. Save the audio separately as a WAV in vdub too. Now in TMPGenc use the video & WAV files to make the MPEG.
Yes, it has been asked alot.Panasonic DMR-ES45VS, keep those discs a burnin' -
thanks. is this the only way though? for "file information" it said mpeg-4 codec for the avi im trying to convert.
not sure if my settings in virtualdub were correct, but it said 4 hours to do half the movie.
is there a tutorial for this? i tried to follow the one from this site, and it simply said to download divx 3.11 aND 4 codecs and install them, then TMP should work. I installed all that stuff and it doesnt. -
try this
In TMPGEnc, select options > environment settings
Next click the VFAPI tab, Right click "Direct Show"do this until its at the top with a value of 4, check avi vfw,avi opendml and select higher priority, -
thanks for thew response but no dice. this is really frustrating. what should the values end up being for the diff priorities? 4 for "direct show" but what about the others?
Brandon try installing the nimo codec pack
<----tools I find this download quite often solves this prob. I haven't yet had a prob with tmpg
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56
