Hey,
Ok, I ripped a DVD. I did the DVD2AVI part and now I am in TMPGEnc.
My movies ratio on the DVD case says 2.35:1. The closest I can get with TMPGEnc is 2.11:1. When I did that all the wheels in the movie are ovals. Everybody also looks skinny.
What should I do??
You can set the source and the output.....Under advanced tab set up source as say 4:3 then goto video and set as 4:3 then before you click start to encode >>click on file then preview....thats what output will look like.....go back and chang settings and repeat till it good.....then Encode.
Does anyone have a preset for 1:1 encoding ratio with tmpgenc plus ?
By LordVader in forum Video ConversionReplies: 3Last Post: 9th Dec 2009, 09:21 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 03:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 18:59 -
Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTV
By iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 01:04
