Hello, another Newbie so bear with me......thanks
These are the questions that I could not find the answers to on the site.
when i use the dvdx guide i can follow it all the way to the end, when i press encode i get the error message MPEGenc:unable to open program file none.mpg Should i have copied the dvd first using smart ripper and then dvd2avi or does dvdx do the work of the other two progs. I'm gettin a bit confused now and would really appreciate some expert help.
many thanks
You have to have installed decoders for MPEG-2. Try to install WinDVD or try to download drivers from section TOOLS and install them.
just wondering if you ever got past that error, or how you fixed it, because i encoded the movie "friday" just fine with no errors and now that im trying to encode "a beautiful mind", im unable to open the movie.... keep getting the mpegenc: unable to open error......the only thing i did different was split the chapters because im burning onto 2 cds.........any info would be helpful.....thanks
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 23:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 02:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 09:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 15:17 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 21:29
