    Jul 2001
    Maryland
    How do I make an SVCD with multipul Sound tracks
    My player allows up to 4
    Jul 2001
    Maryland
    Help
    Dec 2000
    Homebush, NSW, Australia
    I asked the same question here:
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=52517&forum=1
    and got the idea OK. It seems easy, I'm just about to try it also. The only thing you need to be aware of is after demultiplexing your source MPEG2 file in TMPEGEnc encoder in preparation for I-Author's Multiplexor, you need to change the resulting .m2v file extension on the video file to .mpv (I-Author Mux only reads .mpv)
    Graham
