Is their a prog for encoding AC3 Audio?
I wanna make a SVCD with an AC3 channel
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>May I humbly suggest you convert your AC3 to wav and then use the wav in making your svcd. If you are interested I can send you the ac3/wav conversion program.LEGAL AND KOSHER!! -
Yes there is - to be found at http://www.labdv.com/en/examples/svcd_audio.htm
But, your hard work may be in vain, as only a few standalone DVD players will play SVCD with 5.1 digital audio. -
Why don't you checkout the audio tools in the "Download - Audio Tools" section of http://go.to/doom9 - then you can see what works best for you!
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
