Hey people...
to start, beside capturing and transferring my old beta and vhs collection into vcd's i would like to transfer my huge old collections of my vinyls,tapes,minidiscs into music cd's..but the problem is, i dont know how to do it!!!
please people ..enlighten me with your great ideas!!!
massive thanks to you all!!
emgee
What ever the format....first you have to get them onto your computer.....
So if its a record...you got to hook the record player up to the audio in on the PC or some have a line in and record to the hard disc...
The format you want them in depends on what your burner and player supports... Nero will make audio cd's from wave files....so I copy mine that way. -
okay.. so plug in using audio in.. got it.. but using nero? you mean nero cd burner? i thought it is for burning audio cd's or u mean using the nero media player?? is that the only software i'll need to transfer my analog music into pc?
If you want to transfer audio from various sources to your pc the soundblaster audigy platinum is the thing for you. Bit pricey but its got a multitude of digital and analogue inputs.
Craig -
Your sound card should have a media program that will record...If not there is a recorder in the Nero package ...just click on the wav editor icon...it has all sort of options.
New Poll Ideas
By tgpo in forum PollsReplies: 515Last Post: 9th Oct 2015, 06:16 -
Cable storage ideas?
By yoda313 in forum ComputerReplies: 8Last Post: 31st Oct 2008, 00:30 -
Newbie looking for ideas..
By HaleC. in forum Newbie / General discussionsReplies: 8Last Post: 10th Jul 2008, 13:37 -
Big ideas and little knowledge of software out there
By bxcthur in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2008, 14:32 -
Any good ideas for an engagement DVD?
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 22:03
