I captures a VHS tape to my hard drive in DV format, and then produced an Mpeg1 file in Videowave 4.
The filesize was a little too big, so I used TMPGENC to cut it down to size.
Now the video and audio get out of sync as the movie plays.
Is there an easy way to fix this? Should I just re-encode the file?
Also, there is a loud and annoying feedback buzz every once in a while on the audio. Anyone know what that is?
Thanks.
Results 1 to 1 of 1
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 04:14 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
mpeg sync problems after importing dvd
By blubot in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 11:31 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
