  1. HOPE U CAN HELP,I DOWNLOADED TOOLAME FOR TMPGE BECAUSE USING DVD2AVI FOR THE SOUND WHEN BURNED TO VCD THE SOUND HAD LITTLE GAPS IN IT,I SET IT UP(TOOLAME)IN TMPGE,WHAT DO I DO FROM THERE.....HPEFULLY SOME1 CAN GIVE ME A BRIEF DESCRIPTION WHAT TO DO.....(SCOTUK1SCOTTSRIPPER)
    Mar 2002
    chicago
    STOP YELLING
    did you look through the guides here?
    under options, external tools, select toolame as your audio encoder.
    I would also add ssrc.exe as an external frequency converter.
    then you just load your video and/or audio source as normal, and convert. TMPG will use the external tools you specify instead of its own internal audio tools.
    what are you askin' me for...
    I'm an idiot!
  3. ssrc.exe ........whats that could not see it on this site,where do i get it and do i install it the same way as toolame
