hi,
why does the tmpge site claim that you can convert .avi's to .mpg's with version 12i? it won't even let me start with that version. i was lucky enough to find a 12a version which works. is there a trick to the new version? to make a long story short, i tried the new version and it didn't work. i found an 12a version and it worked except for one .avi that i have that stops running at about 15% of conversion. is there something different that you have to do with the new version? it won't work with any .avi that i have. i went into settings and set them according to pal or ntsc as instructed. someone please enlighten me. also, why would a file stop converting? does that mean the file is corrupt? it plays fine as a .avi file. HELP?
nick
IF you find out why let me know becuase i am freaking ticked that no one helps me becuase anything above 12a wont open for me it sucks!
please tell me your system specs maybe its something we have?
write me back please
On 2001-08-04 16:08:03, nick177th wrote:
hi,
nick
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
Usually the problem with opening an AVI is related to the VFAPI Plug-in priorities in the environmental settings under options in TMPGenc.
You can change the priorities by right-clicking on the plug-in and selecting higher or lower priority.
I have AVI2(OpenDML)File Reader as my top plug in and AVI VFW as the lowest. You may have the VFW at a higher priority than the AVI2 and it can't read all types of AVI files. Hover your mouse over the plug-ins to read about them.
Play around with it, let me know if it works for you.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc Xpress FPS trouble
By shorto in forum Video ConversionReplies: 0Last Post: 6th Sep 2007, 18:59
