I'm copying DVD segments, none of which are more than 47 minutes long. Under the bitrate tab, it appears that anything under 50 minutes should fit on a 74 minute (650 meg) CD. But the resulting files I'm getting are all between 700 and 750 megs. What am I doing wrong?
dvd2svcd allows for the maximum size on a given media. As mode2/XA
allows roughly an extra 100 meg's (due to the lack of error correction)
to be recorded, this is what dvd2svcd aims for:
ie. a 74min CD = 740 megs (not including overburn)
a 80 min CD = 800 megs (not including overburn)
Is using the entire CD a problem? -
Well... I don't know if it's a problem. See my post in Software Playing: http://forum.vcdhelp.com/viewtopic.php?t=97347
Well, you must have found out by now that the filesize is not a problem.
I hope you you have succeeded to burn the bin/cue file to CD-R. If not, then try this: DVD2SVCD also did an Mpeg file as output. This is the actual movie file. Just load this file into NERO. If NERO does not complain, then you will have most probably a correct SVCD.The Dutchman -
Thanks for the reply. I finally tried the SVCD on the latest version of WinDVD, and it worked fine. I also went to Best Buy and tried it on a standalone player (a JVC XV-S300BK), and it played perfectly. So I'm happy for now.
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 23:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 22:03
