Look my config, K6 500 scsi 2gb (windows 98 within this), 40 gb ide, isa soundblaster 32, 128 mb ram, pinnacle studio pc standart drivers for it. With this config, using audio 22k/8/m mjpeg quality 20 25 fps, I have perform of: 201233 frames, time 2:14:18 and 204 frames dropped. This quantum of drop frames is ok or is possible improve it? Using Win2k, WDM drivers and other software unlike virtualdub can I get better results?
I use a K6 500 with a matrox card and capture with matrox mjpg and picvideo mjpg 44k sound, quality 20 averaging 2 drops per hour using AVI_IO
Mickle -
Please, let me know more details: about your motherboard, grafic board (agp?), Is your hd 7200 or 5400 rpm ? Do you have a single hd or you capture in another hd? Do you use Win2k or 98? Do you capture in 640x480 or minus (I use 320x240)? Do you use the WDM drivers? Did you have done some tweak in your configuration? Maybe in the my capture card the problem? I'm looking for where is my bottleneck, I believe that you and others users can help me. Thanks.
Celeron 466 @ 550 with 256MB.
ATI AIW-128 32MB PCI.
Win2000 SP2 - DirectX 8.1 - MMC 7.2
Maxtor 80GB 5400rpm (NTFS) on UDMA66 controler.
For 2 hours capturing in VirutalDub at 720x576 25fps, Audio PCM 16bits / 44khz , its drops around 20 frames on average using huffyuv or PicVideo.
Settings :
Video buffer limit = 80
Audio buffer limit = 0
Audio buffer size = 0
(I've reduced frame drops a lot since I set audio buffer to 0).
Disk I/O:
Chunk size = 512 Kb
Chunks in buffer = 2
uteotw
Which is better for speed and performance?
By SIRCOOKS in forum ComputerReplies: 3Last Post: 20th May 2010, 23:03 -
Concerned about PC performance
By mattman1968 in forum ComputerReplies: 4Last Post: 23rd Oct 2008, 11:31 -
FFMpeg performance
By aeroliteflyer in forum DVD RippingReplies: 12Last Post: 18th Mar 2008, 20:47 -
CRYSIS performance
By retroborg in forum Off topicReplies: 4Last Post: 13th Dec 2007, 07:55 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 11:31
