Ok. I try to frameserve with virtualDub, and when I open the file whith Tmpgenc, it can't recognize it.
I use Virtualdub 1.4.10. ; Tmpgenc 2.53.35.130
I make a new installation of windows 98se on my disk. I made all instructions of the "How to section (www.vcdhelp.com/virtualdubframeserve.htm)"
Always the same error msg......![]()
I read in this forum taht the msvcr70.dll could make some problem if it wasn't in the "window\system32" directory.
Could it make problem with Windows 98se (I don't have this dll on my disk) ?
I found msvcrt.dll, msvcrt20.dll, msvcrt40.dll in the "windows\system" directory.
I hope someone could help me.
Thanks by advance.
there is a bug in 1.4.10
get 1.4.9, or try using avisynth instead--it's quickerwhat are you askin' me for...
I'm an idiot! -
Yes, you need that dll, even with SE. Search on www.google.com for the dll. 8)Originally Posted by PMangouste
I added the dll in the windows\system directory, and now i can frameserve
Many thanks for your help.
It will be great to add this point in the FAQ section no ?
http://www.vcdhelp.com/virtualdubframeserve.htm
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 05:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
