I am trying to compress a 2 and a half hour movie for sharing over the internet. I have tried vitual dub but I am not too sure what settings to put on there. When I try to convert anything with vitual dub using that "how to" menu to the left, it freezes or doesn't do anything. Is there a simple program for MPEG-1 to Divx for idiots like me? Or can somebody help with my vitural dub problem.
Select Video > Compression > DivX MPEG-4 Fast-Motion, click on the "CONFIGURE" button.
The Fast-motion codec offers better quality in movies with a lot of action and if you use a lower bitrate.
The Low-Motion is better quality, but may increase the file size.
A new window should open, and here you can fine tune the encoding
Keyframes 10 (1 - 5) for smaller files
Smoothness/Crispness 100% might give jerks, try smaller values
Data Rate, the higher the number the bigger the size, if the original is high quality, 250 will work fine.
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 10:04 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 19:59 -
Divx/Mjpeg to Mpeg-4 with VirtualDub
By nalooti in forum Video ConversionReplies: 2Last Post: 16th Nov 2007, 22:50 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 03:16
