Hi,
I need help with capturing with my Belkin USB VideobusII.
I have:
- AMD 1700+ CPU, 256 Megs of ram
- WindowsXP
- Using virtualdub
- 40 gig HD, IDE 7200RPM - ATA100, spilt into 3 partitions, 2 are Fat32 and the other is NTFS made specifically for capturing footage into. It is 5 gig. Also DMA enabled.
I Capture at 352x240@25fps with no compression for video.
I get a heap of dropped frames maybe 50% are dropped frames.
What is wrong? I have tried everything. Please help me.
You used the two magic words
USB and Uncompressed
USB 1.1 - which the Videobus uses is not capable of moving uncompressed video across the USB interface without drops.
Try changing the video mode to yuv2 or almost anything other than 16bit or 24bit, then run this through a codec.
Most video drivers allow you to change this - try it you can't hurt anything
If you are trying to cap uncompressed try using HuffyUV - it is a lossless codec that uses yuv2 data natively -you can find Huffy in the tools section of this web site
Also I checked the Belkin web site for some info on the VideoBus 2 - and unless you are also using a notebook for capture - get yourself a PCI based capture card, you will have less problems - something based on the Conexant / Brooktree BT878 chipset will keep you out of trouble.
Hope this helps even a little bit
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing video
By samiamk in forum Newbie / General discussionsReplies: 12Last Post: 3rd Dec 2007, 13:16 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
