I am having trouble encoding some Divx movies with TMPEGnc. If I open the Divx file with windows media player it will play the Divx file. But when I go to encode the Divx file with TMPEGnc, I have audio and no picture. I have the newest version of TMPEGnc 2.5. I have tried an older versions of TMPEGnc and experience the same problem with both versions.
Any help would be greatly appreciated.
Vacman37
Results 1 to 9 of 9
1, load AVI into Vdub and scan for bad frames. Video > Scan video stream for errors
1b If it finds bad frames, set video/audio to streaming and SAVE AS, save out another copy of AVI
2, Now that the AVI is junk free, load into TMPGENC.
2b Select options > environmental settings
2c click the VFAPI plug-in tab
2d right click the "DirectDraw" and select higher priority, do this several times until its at the top with a value of 4 -
Originally Posted by KingJohn
Every time I open a AVI into VirtualDub, VirtualDub it crashes. Can you help with this problem.
Vacman37 -
re-install the latest DivX Codec.
re-install VirtualDub
Make sure that you RESTART your computer after you reinstall the DivX Codec. VERY IMPORTANT!!!...
if you still have problems you might wanna do some system maintenance checks (e.g. scandisk, virus check...)Big_Jit -
vacman37,
The problem might be you have not got the correct codecs loaded.
If you are sure u have the latest codecs then the very next
thing is to save the sound to a seperate wav file and
use the divix source as the video, and the wav file as the
sound. -
Right click AVI select properties, look at the codec information, make sure you have the codec.
If you have SMR (Angel portion) installed, un-install it, its full of bugs, then install the Nimo codec pack
Nimo, should fix this problem anyway. -
Originally Posted by vacman37
Vacman37 -
see here for fixing the problem
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860 -
I had to uninstall the Angel positioning codes. Thank you all vety much for your help.
Vacman37
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Sound but no Picture?
By Soulfinger in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 18:10 -
I have sound, but no picture?
By TSI_AWD in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:59 -
No sound but picture works
By tou in forum MacReplies: 6Last Post: 12th Oct 2007, 17:36
