Hi
I want to convert a avi to mpg, but there is some "white dot's" on the file.
I have tried different filter with VirtualDub and TMPGEnc but it is difficult to remove the dots.
Can anyone give me a tip of how I can get rid of the dots?
Are there any filter or method I can try out?
The avi is a VGA (640 × 480 pixels) from my Fuji finepix S602Zoom.
Best regards
Results 1 to 9 of 9
Trux - Norway
Hi
How do I post a screenshot on this forum?
I am new on this.
RegardsTrux - Norway -
Well - there's a img button up on the message body but it looks like it requires a web site, if you don't have a web site then I'm not sure how to post an image
Hi
It is difficult to see the dots but when I show the clip on a Windows player it is show a lot.
http://no.photos.yahoo.com/bc/trondkri/lst?.dir=/Test&.src=ph&.done=http%3a//no.photos...view=t&.view=t
Regards
[/url]Trux - Norway -
No that's great- I can see them
I see what you mean now
Do the dots -
come and go as the video plays
move around as the video plays
Are the dots on the original captured footage?
from what you said in the original post this is a digital camera with an avi feature? -
Actually the more I look at the spots the more they look like this
http://www.mediachance.com/digicam/hotpixels.htm
Good little page about this - but according to this it should only appear with long exposure times not on bright sunny days like yours
do.
do you get similar spots if you capture images at the same resolution? -
Hi
I dont get any white dots with ordinary photo(stills).
Yes, this is the new Fuji finepix s602s with full VGA video.
Someone have a ide if there is some filter who can remove
dots like this from a AVI or MPG?
I know that the digicam never will produce video with quality like a DV-
cam, but it could be fun to see if some tools/filter could remove dots like this.
Other than some of the noise removers - like smart smoother or HQ-smoother
they should remove some of the dots but most likely wipe out some needed picture information as well.
Have you talked to the place you bought the camera or even Fuji Service center near you?
Maybe the camera has a fault - I have seen a couple of of movies from different brand cameras and never seen that problem before - except in the instance of that web page I sent you.
need method for video noise reduction
By codemaster in forum EditingReplies: 2Last Post: 1st Jan 2012, 17:10 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 21:14 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 07:08 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 06:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 19:22
