when trying to split a vcd compliant mpeg I'm ending up with the resulting portion come out perfectly video-wise, but after 4 minutes in, the audio cuts off...tried it 4 times with the same result at about the same time segment....i'm using the freeware version and my hard drive has 4 gb open, the video is 1.2 gb and I'm cutting down the middle - any thoughts?
I see that the new version can convert AVI's that have bad frames, before it use to warn/crash I'm wondering if this is a good thing.
If the AVI is converted and TMPGEnc does not give an error, will that mpeg be able to be split/merged like before.
If the split merge has not been updated then this might be a problem. ?
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 07:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 11:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 02:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
