Hi All,
I am having a problem with a few of the movies I have ripped. When I play them back on my DVD player every once in a while a few frames of the movie will speed up, like it's in fast-forward, and the audio will loose synch briefly, and then it's fine again. This doesn't happen on all my movies, just some. I am guessing it has something to do with the settings in TMPGENC, but I am not sure what.....or, it could be something to do with the settings in DVD2AVI. The problem is that I have tried a few different tutorials on DVD Ripping, and each one is slightly different, and I am not sure which method I used for which movies. Anyway, anyone else seen this problem??? Does anyone know what causes this?
Thanks!
Andie![]()
Video is blurry on computer but clear on HDTV, how can it happen?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 11:48 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 12:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 02:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 05:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32
