ok dvd2avi is suspose to convert vob files to avi.right?now after it converts the vobs the files that dvd2avi have created are d2v.how come it is not an avi?i cannot load this d2v file into the avi fix program to try and fix audio sync probs because it it say this file is not a riff file.how do i do this?someone please explain im confused.
IF your useing DVD2AVI and the result is a d2v file, then you must be saving as project and not AVI. If you want an AVI, then you have to save as AVI. The d2v file is for TMPEngc, the next stage..
Have a nice day....
Can someone explain how it's possible? 1080p at 1.17GB ?
By smackyourfupa in forum Newbie / General discussionsReplies: 4Last Post: 12th Feb 2011, 10:11 -
Can you explain this noise in XP ?
By Seeker47 in forum ComputerReplies: 20Last Post: 9th Oct 2010, 05:24 -
Explain a child domain?
By capman21 in forum ComputerReplies: 1Last Post: 30th Sep 2008, 23:41 -
Can somebody explain the problem with this dv footage.
By Aarzoo in forum RestorationReplies: 8Last Post: 18th Jul 2008, 09:28 -
can someone explain?
By icucmerc in forum Video ConversionReplies: 2Last Post: 4th Aug 2007, 10:57
