I just keep getting problems, after installing w2k...
In Ati Tv, whichever codec I use, my video just loops the first 1-2 seconds, audio goes on.
And in vdub, all I get is green video without sound.
I'm really hopeless, everytime I defeat a problem, there is always new one right after it.
Again, hope is very much apreciated, and thanks to those who helped me on that MMC tv problem.
This sounds as if Macrovision is the problem. I'm not aware of any way to disable it in an ATI card. You have to get an external device - the SIMA video enhancer works great.
I was having problems even with home videos. The AIW card was treating them as if they were copyrighted. I got the SIMA and those problems went away. I still have been unable to the Audio/Video sync to work correctly with the ATI. I finally gave up and got a Dazzle 200. -
Problem solved!
Anyone else with similar problems, use this
http://www.vcdhelp.com/download/MMC_7.5_7.6_Reg_Tool_Final.rar
and disable Macrovision. -
The macrovision fix worked fine for my Radeon AIW. Before I used it I would get the same video loop while the audio keeps going. I installed the fix and captured the same source and I had no more problems. Audio and video are in sync, also.
S-Video Vs Composite for Black & Whit captures
By nharikrishna in forum Capturing and VCRReplies: 29Last Post: 8th Sep 2011, 23:30 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Front page went loopy ?? LOL!!
By Noahtuck in forum FeedbackReplies: 9Last Post: 11th Sep 2007, 14:00
