Hi guys.....my problem is that I just burned a vcd and when I played it on my computer it worked perfectly fine....then when I played it on my dvd player...green boxes started appearing on the screen.....and it was all weird......what's wrong....I've burned about 10 movies and this is the first time it has happened.....plz help me.....
Check the obvious, stratched/dirty disk maybe.. or the CD may well be just a dud... does this happen with all the movies you burn?
I had the same problem with the first disc I burned, so I tried burning it at a slower speed (16x down to 4x) and the problem cleared up. Hope this helps.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
