  1. When converting *avi to *mpeg with TMPGEnc I did this:
    Video
    Stream type MPEG-2
    Size 352x288
    Aspect ratio 4:3 Display
    Frame rate 25 fps
    Rate control mode Constant bitrate (CBR)
    Bitrate 1150 kbit/sec
    VBV buffer size 0 (Automatic)
    Profile and level Main Profile & Main Level
    Video format PAL
    YUV format 4:2:0
    DC coefficient precision 8 bits
    Motion search accuracy High quality
    Audio
    Stream type MPEG-1 Audio Layer II
    Sampling frequency 44100 Hz
    Channel mode Stereo
    Bit rate 224 kbit/s
    System
    Stream type MPEG-2 Super Video CD (VBR)
    Advanced
    Video source type Non-Interlaced
    Field order Even field first
    Source Aspect Ratio 4:3 625 line (PAL)
    Image positioning method Fit to frame (preserve aspect ratio)
    blah,blah,blah
    So my point being:
    It all works swell, when I play it on my computer, BUT-when I try to play it on my -stand alone- DVD player (X-wave), I get a dick.
    X-wave is capably of playing VCD’s ( I know ‘cause I have a couple of those-obviously- done by someone else ).
    When I compare properties of the one’s that work with the one of mine, the only difference (as far as I can see !?) is that, the good once are *DAT files and mine are *MPG.
    CAN ANYONE HEEEEEELP !!!
    Please !
  2. typically if you open the folder mpegav on the disc and its a dat file then you have a VCD, if you open the folder and its mpg then its SVCD (typically).
