I am having a problem with VCDEasy. I have used it before, and was able to add files just fine. However, when I try to add files now it gives me the following error:
"filename.mpg"
"352 x 240" is not a valid resolution for a "PAL" encoded sequence.
I am doing everything exactly the same as I did the time when it worked. Any suggestions as to what I need to do?
Thanks,
Sheryl
PAL mpeg files (VCD) need to be 352x288 resolution. The one you are using is an NTSC one. In VCDEasy using Settings, (S)VCD Player try changing the preferred tv system to NTSC
Thanks. I tried it, but it didn't work. I received the same message. So, now I am trying to re-encode with 352 x 288 resolution. However, as I mentioned before, I did use PAL encoding with 352 x 240 in with another dvd, and it worked just fine. Any ideas as to why? The reason that I originally did it with 352 x 240 was that I read somewhere that if you were in North America, you should use that resolution. Wrong advice?
If you live in North America, you should be using NTSC settings. For VCDs, the resolution will be 352x240 with a framerate of 29.97 fps.
The framerate is most important.
If you are encoding with TMPGEnc, be sure to load the correct template.
Is there any reason why you are encoding to non-standard resolution/framerate combinations?
Regards.Michael Tam
w: Morsels of Evidence
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 05:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 21:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13
