  1. I captured a show from my vcr with the .mp2 extention. I can play it in windows media. When I use vcd easy to make a vcd I can't add it to the list to be burned. When the box comes up to show available files only mpeg2 is available. I thought mp2 was the same as mpeg2 or mpg2? When I captured it I thought that is what the extention was supposed to be , but it came as .mp2. Can I fix this or should I just delete the file and start over?
  2. Rename the file .mpg
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. I tried to rename the file in windows explorer using the rename, but can't change the extention. How do I do that?
  4. Use a DOS box to rename?
