Now available
http://www.tmpgenc.net/files/TMPGEnc-2.55.38.142-Free.zip
Changes from TMPGEnc v2.54.37.135 to TMPGEnc v2.55.38.142
Outputs as OpenDML format for AVI file output. The first 2GB part of such file can be recognized by conventional VFW application.
At project wizard (4/5), if the capacity exceeds 100% such part of the bar becomes red.
Bug fix : at source range, if after 32767 frame is displayed, mouse wheel could not be used.
Bug fix : at preview of clip frame setting, always resized with interlace if output horizontal resolution is larger than 480.
Improved seek speed on loading AVI file
Bug fix : at cut editing of source range setting, the actual amount of audio gap correction was doubled.
At MPEG setting, if system stream format was changed, the aspect ratio of video stream was not converted correctly.
Results 1 to 1 of 1
TMPGEnc Authoring Works 5 Version & HD-PVR Question
By TBoneit in forum Authoring (Blu-ray)Replies: 25Last Post: 18th Nov 2015, 17:20 -
Tmpgenc Authoring Works Version 4.0.7.32 - November 9, 2009
By juliocesar in forum Authoring (DVD)Replies: 3Last Post: 27th Nov 2009, 05:05 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 09:25 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 13:55 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
