Hi, no matter how I capture stills off some RM clips while playing it with Real One player (print screen, screen capture programs, etc.) the play area is always black in the resulting JPEG. Any one any thoughts? Thanks.
There is a program called Tinra (this is not real anymore) which will allow you to convert it to another format. You can then use your favourite edit program to extract the frame you want. The site moves around from place to place, the current site is http://guiguy.wminds.com/ or do a search for tinra on your favourite search engine.
Thanks for the suggestion, althought I don't want to convert the entire RM clip into something else just for capturing a couple of screen shots.
Also went to real.com's knowledge base and got the answer. Learn something new every day. Thanks again:
When you try to capture a screen shot from RealPlayer or RealOne Player, the video window in RealPlayer will not show the video image that was playing in the window at the moment the sreen shot was captured. To correctly capture a screen shot of the player that includes the video window image, the "Use optimized video" option has to be turned off. Then capture the image using the instructions below...
Capture files over HDMI on Canon XA10
By shane123 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2012, 02:47 -
capture/burn text files
By jamestk98-1 in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2012, 07:55 -
Easycap usb large capture files
By visionman in forum Capturing and VCRReplies: 5Last Post: 4th May 2010, 17:23 -
I am trying (and failing) to compress capture card files....
By ladyhawke in forum Newbie / General discussionsReplies: 8Last Post: 30th Jun 2009, 21:55 -
AVi files transfer(capture) does this sound right?
By caveman in forum Capturing and VCRReplies: 3Last Post: 25th Oct 2007, 21:18
