  1. Right...
    I've just found out my DVD player will happily read DVD-Rs, which has made me a happy lad. I'm quite confident that this is possible, but not fully sure.
    Say I have about 10 .mpeg files on my hard drive, all about 400mb each.
    What I would like to do, is to burn them onto a DVD-R, and be able to select an episode to watch on my DVD player.
    Secondly, I could make a menu which would let me to pick an episode straight away as well couldn't I?
    Kind Regards,
    byb
  2. As long as your mpegs meet dvd spec you should be able to put them on to DVD-r using a DVD authoring program. Be aware that this requires the audio to have a 48Khz sampling rate so if they are (S)VCD you will have to extract and convert the audio first. See the guides for how to do this.
    As for menus, yes you can have a menu button for each movie.
