  1. I made a file with Sub Station and I added it to a movie file and it was placed on the movie just fine except for the fact that the text with so small it was just a little yellow blob at the bottom. Anybody know how to change this? I'm at ps2guy525@yahoo.com
  2. how did u add the subtitle to the movie? U just loaded the sub on the movie? If it's that, u just need to put the fonte larger, in the program itself...
  3. the thing is I'm not sure how to make to font larger in the program itself
  4. I Think I can help with that.
    OK...
    Open your subtitle in SSA.
    1: First habe a look, witch style is used for your subtitles! Mostly the default style.
    2: Go to STYLES, DEFINE, EDIT. Now you can edit the style.
    greets
    CryptKeepX
  5. Thanks. I know that was a bit of a dumbass question.
