When I use the Pinnacle PCTV Card(with the software that comes with it) to Capture straight to MPEG, the sound is late 20-30 seconds(1 hour movie). When I use VirtualDub Drops frames like crazy. I can only capture 352x288.
1600XP
7200 rpm HDD
256 Mb.
Please Help.
Turn off all background apps. (virus scanners, etc..)
Make sure your drives are in DMA mode. -
alexb,
You haven't given much detail about your system or proceedure. If you have a look at the following forum thread it contains the hardware setup I have and the programs and settings I use to capture through the PCTV Card.The only things I have changed since then is an upgrade to a Pentium 3 and I only capture at 480 x 576 regardless of the source.
http://forum.vcdhelp.com/viewtopic.php?t=74588
Hope this is of help to you.
Ronin2 -
Also, check this thread for optimizing the HD settings. I am also using the PCTV card.
http://forum.vcdhelp.com/viewtopic.php?t=96827
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
Pinnacle PCTV HD Ultimate Stick
By bigjimmpls in forum Capturing and VCRReplies: 19Last Post: 28th Dec 2007, 15:40
