hello
the problem is: when i watch a video with premiere 6, i have a cracking noise on the sound,that noise is regular, but i don't have that noise when i watch that video with the windows media player. how can i change that?
thank you
ummm, try this it might work
load the video
do you see where the audio track is....
to the left there is a box to expand the audio (to see the wave pattern)
expand the track
now if you click on the wave (it should place a red dot)
and create a line and click again on the other end of the audio ( go from left to right )
what I am really trying to tell you is you can lower the volume on the audio, it sounds like a hard thing to do when you can just turn it down so to speak, but what you are really doing is cutting off some of the peaks and hopefully the noise your getting is in the higher peaks (the ones you cut off )
if you need more help feel free to email me
title it "prem6 help"
FenDers
"Hail to the King, Baby"
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 17:21 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
Using Adobe Premiere with EasyCap
By SRiffer in forum Capturing and VCRReplies: 0Last Post: 10th Nov 2008, 14:44 -
Adobe premiere pro 2?????
By Reggie6966 in forum EditingReplies: 10Last Post: 19th May 2007, 22:18
