Is there a good authoring program that supports motion menus and files of type m2v and ac3. Thanks in advance
I use DVDit! LE 2.5. It appears to allow you to drag mpg's, m2v's, and/or wav's to the menus. It definitely allows m2v's as movies. It recognizes chapter points in the movies, but doesn't create new ones for you.
The only thing it doesn't handle is AC3's. It insists on either MPEG-1/2 layer II (mp2) or PCM (wav) for audio, and transcodes the former to 48kHz PCM stereo which takes up valuable space on the disk.
I think the SE or PE versions might do ac3, but they are something like US $500 and $1000 respectively, so I'll stick with LE (which I got free with my DVD-RW drive plus a 19-hour download to upgrade 2.4 to 2.5).
Good luck -- I hope to hear about more authoring s/w as other posters reply. -
DVD Workshop does motion menus/motion buttons. No AC3, but an update is coming in July sometime to allow it. Not sure about m2v files.
/\/\ars /\/\ayhem
Authoring program for sub/idx ?
By Capum in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2010, 16:15 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10 -
Authoring an NTSC program
By spliffy in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 16:19
