  1. I open the avi file with VirtualDub, then I select START FRAME SERVER. I creat the VDR file. Then, in TMPGEnc I click on Browse, select the VDR file and the following error appers: File C:\Windows\Desktop\star.vdr can not open or unsupported.
    I used to do this, and this problem didn't happened... It started when i change the version of both programs...
    can anyone help me?
  2. I know this doesn't help - but im having the same problem - but with Premiere - and I have all the patchs and import filters installed.
    Ok - you got me - i dont know anything - you happy now!
  3. yeah, let's wait someone to help us
    May 2002
    Rainy City, England
    You need to get hold of msvcr70.dll and copy it to Windows\system32. Then you will probably need to play around with the VFAPI priorities. IIRC it is the project reader one which needs increasing. Then you will be able to load in the .vdr. 8)
  5. wow! wait!! two much information for me hehhe. what is VPAFI and IIRC??
    Apr 2001
    Puerto Rico, USA
    Do a search in the Net for:
    tmpgenc-readavs.zip
    It's a filter that will allow you to frameserve Avisynth AVS files and VirtualDub VDR files to TMPGEnc. It works great.
    Good Luck!
    May 2002
    Rainy City, England
    Options>Environmental setting>VFAPI plugin. You should see a list of plugins, and you can change the priority of individual ones.
    IIRC = if I recall correctly 8)
  8. Originally Posted by banjazzer
    wow!!! i just tried now! i just put the DLL in the windows folder! it worked!
    thanks man!
