Ok, everyone knows that trick so you can play SVCDs on VCD-only standalone players, right?
I use DVD2SVCD to create MPEG-2 VBR files, which I later single-multiplex to MPEG-1 VCD in TMPG so that my standalone player can read them when I burn them as non-compliant vcds in Nero.
Usually, with 2-CD encoded movies, the output mpeg is a bit smaller than the input one, which is fine.
Now, sometimes, I try to make ONE-cd movies, but the output single-multiplexed mpeg is A LOT bigger than the input one, about 300 MB bigger!
If I multiplex it to "MPEG-1 VCD Non-Standard", the file size is "correct", but I have A/V desync after burning.
So, any ideas on making a one-cd SVCD with VCD header? Any ideas on the best way of burning your mpeg files to VCD?
Thanks in advance!!
the only problem I see here is standard VCD is CBR, and you are using a svcd that is VBR, just changing the headers will not change the bitrate.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
MTR-Toast Multiplex problem
By danielmak in forum MacReplies: 0Last Post: 20th Feb 2010, 10:31 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 11:15 -
Unwanted Single frame problem
By Redcliffe in forum Capturing and VCRReplies: 5Last Post: 20th Jan 2009, 16:15 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 03:40
that's good, because i want to keep that bitrate
