Hi All,
Does anyone know of any software to capture single frames from a DV camcorder using a firewire card ?
Preferably free, as I'd like to try doing some time-lapse work.
Cheers
Stuart
If you buy a firewire card, they used to supply free Video capture and editing software (like Ulead Videostudio etc..)
Still you want free stuff, you can search in this vcdhelp.com site. They have software and link to other sites where you can download trial version or freewares.
Ok, perhaps I'm missing something here then
I've got Ulead Media Studio, which does allow me to capture the current "live" frame to an image file. but what I'm after is something that will capture a frame every x seconds and record it to mpeg/avi file -
If you can use Virtualdub to capture then you can hit Ctrl+1 to capture source frames and Ctrl+2 to capture output frames. You might wanna capture a video sequence and then extract your frame sequence...
Big_Jit -
Look at the newest guide - it works in WinXP and will do timed saves.
Enjoy!Panasonic DMR-ES45VS, keep those discs a burnin' -
Sorry - I tried to find a free solution. I couldn't find another.
How to calculate single frame duration
By 8day in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 11:49 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Unwanted Single frame problem
By Redcliffe in forum Capturing and VCRReplies: 5Last Post: 20th Jan 2009, 17:15 -
Videoredo Cut a Single Frame ?
By acestu in forum EditingReplies: 4Last Post: 3rd Sep 2008, 10:06 -
Adding Text to a Single Frame
By dogberry578 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2008, 17:03
