Using Nero (or another burning software), is it possible to burn several MPEG-1 files onto a DVD-R and have them play in a standalone? Essentially, the disc would be an oversized VCD. Has anyone tried this?
This has been discussed 100s of times before and there is even a guide under the how to's and then author.
Matthew -
I know how to re-encode the audio and author it as a DVD. I'm asking if it can be authored as a VCD? Without using SpruceUp or DVDit or any other Authoring programs. Can i just load my files into Nero, burn it, and have them play?
I think he means burn a VCD file-structure on DVD media. Oversized VCD.
Interesting idea - I don't know. Can't try it. Some DVD players check media type and switch over automatically. That's why miniDVD doesn't work on most players. As soon as a CD is detected, it assumes it must be VCD (or SVCD if the player is capable)./\/\ars /\/\ayhem
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 27th Apr 2012, 23:39 -
DVDRebuilder/HC Encoder making oversized file
By ricoman in forum Authoring (DVD)Replies: 8Last Post: 2nd Aug 2009, 15:10 -
DVD Video Image Oversized Question
By JerryRecords in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 11:14 -
Oversized video file...
By Felo in forum Video ConversionReplies: 3Last Post: 18th Jan 2008, 02:14 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
