  1. Hello, can someone that has successfully backed up SHREK to one DVD-R provide some steps by steps. I've tried various ways and the multi angle processing is driving me crazy. Even if it's just the movie.
    Thanks!
  2. C'mon folks, I can't believe no one has ripped SHREK. I would like to get this done before my son burns the original out. It gets played about 5 times a day.
    Thanks again!
  3. I ripped it and it all fit onto a DVD-R. I used DVD Decrypter and then IFOEdit. Stripped out everything but one sound track and the movie and it worked fine.
  4. Multi: How did you handle the different angles?
  5. There is an option in IFO edit to remove MultiAngle pointers.
  6. Okay, this is where I'm at.
    1. Ripped SHREK using DVDDecrypt, selecting all files, keeping angle 1.
    2. Used IFOEDIT to remove all subs and audio except the main one
    and the resulting ouptput is still bigger than 4.7.........any ideas?
  7. marcovan,
    If the resulting output is still larger than 4.489.25 GB (4.7GB) then you will need to re-encode the movie. Try using TMPGEnc or ReMPEG to shrink the movie down. Use the following as a guide...
    http://www.dvd2dvdr.com/
