I am really inexperienced, and the VirtualDub filters to remove subtitles are so complicatd I don't even know where to begin. Any help?
The Vdub filter (Logo-away) etc, will put a block on top of the text, it wont remove any subs as they are now part of the picture.
If they are in the black borders, you can crop them out, anywhere else, Forget it !! -
Use this method (copy of TMPGEnc 2.55x required)
1) With TMPGEnc, under video source, open up the
dat movie file on your vcd.
2) Click on settings, click on the advanced tab, double
click Clip Frame and set mask to crop out as much of
the sub titles u can
3) Click on File, then output to file, then mpeg, then give
the saved movie a name.
Was there ever a case where deinterlacing would simply not work?
By mazinz in forum RestorationReplies: 11Last Post: 25th Jan 2011, 04:53 -
how to remove subs embedded with all to avi
By pike8 in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2009, 11:42 -
Remove ads, subs and audio that I don't need and modify buttons
By Brent.M in forum DVD RippingReplies: 8Last Post: 13th Aug 2008, 10:38 -
Batch remove audio/subs
By BVT in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2008, 12:58 -
How to simply turn off MKV subtext
By hanugro in forum EditingReplies: 4Last Post: 18th Nov 2007, 03:49
