Hi.
For the past few days, I have been playing vcds in my computer. Almost always, at the end of the VCD, the computer start to twitch (make sudden jerking movements) while the VCD is playing. Does anyone know why this happens? I tried in my work computer but the VCD is playing normal as usual. There are no (not even a trace) twitches at all. The flow of the video is smooth. No matter what player I use, Window Media Player, PowerDVD, everytime the same thing happens in my computer. Sometimes, the computer just hangs. Even if I copy the dat file from the vcd to the computer and play it, same result.
Does anyone know how can I solve this problem? Please help me urgently!!!!![]()
Thanks,![]()
Kamal
try copying the disc to another disc and then try...
Big_Jit -
I tried that also but I don't know it has the same problem. What I think is that something is wrong with the cpu. Because I tried it in my friend's computer and there were no twitches at all! Surprising!
Kamal -
It may be that your system resources are low. Try turning off some of those icons on the taskbar and turning off some applications before you begin watching...
Big_Jit -
then it must be your cdrom.
the spin at the end of the disc is not the same in the beginning
Try onother cd or dvd rom (or use a better cdr / cdrom combination )
Try burn at lower speed , older cdroms cant handle fast speed writing
But i dont no why it do that on your hd !
good luck -
I think it is my cpu only. Anyways .. thanks for all the response. I will try all the suggestions.
thanks once again.
Kamal
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 08:50
