Hi,
I'm helping a friend to backup a copy of his DVD Karaoke to a VCD Karaoke. This is my first time doing a DVD Karaoke back and notice there is lots of halo or blocky or haze effect around the karaoke text. The karaoke text is not subtitle but part of the video itself. I have tried both using the CCE demo and TMPGenc. I tried all kinds of settings and searching through forums and guides for the past week already. But still no such luck.Is this normal to have halo/blocky effect around the karaoke text if using VCD? Is there anyway I can minimize or reduce the blocky effect on the text? Any suggestions would be very appreciated.
Thanks.
-Kenneth
With CCE set quality to 3, multipass to 4
With Tmpge set res to (PAL 352x576 / NTSC 352X480)
Use a CQ setting of 95-100, activate "no motion search for still picture by half pixel" -
Using this setting below for either CCE or TMPGenc will create a non-standard VCD right? I need to create a standard VCD and at the same time try to reduce those blocky karaoke text.
-Kenneth
Originally Posted by offline -
unfortunately the standard does exactly what you don't want.
I guess you could stay within the standard with tmpge and try selecting CG/ANIMATION under quantize matrix and Soften block noise.
This may help. Also look at better ways of transfering the DVD
movie to vcd (aka Avisynth & bicubic resize)
What is the a good/best program to reduce as much pixellation or blocky?
By Milardo in forum EditingReplies: 16Last Post: 5th Jan 2011, 15:41 -
How to add simple permanent karaoke text to music videos
By kschang in forum User guidesReplies: 12Last Post: 14th Aug 2010, 16:34 -
How to make a karaoke VOB file from 2 (one audio and one text)?
By coxanhvn in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2010, 00:57 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
Cursive writing text effect
By bearsbowl37 in forum EditingReplies: 2Last Post: 14th Nov 2008, 20:34
