  1. Having problems with multisegment capture in VDub (see my previous message) and was going to try AVI_IO as the last resort before maybe going to upgrade to XP.
    There doesn't seem to be any mention of frameserving in AVI_IO, so how do you get all the avi segments into TMPgenc without any joins ?
    Thanks.
    Tone.
    Aug 2001
    Melbourne
    AVI_IO will automatically create multi-segment AVI capture files which are compatible with VDub. Open these files up with VDub, apply whatever filters you wish and frameserve to TMPGEnc.
    Hope this helps you.
    Ronin2
