  1. Hi folks,
    The question is: Is there a quick way of taking a 4:3 aspect ratio MPEG-2 and change the aspect ratio info (some header?) to 16:9? I want to leave the resolution, bitrate in fact everything alone apart from the aspect ratio.
    Cheers,
    Bolix
    Feb 2001
    Berlin, Germany
    There are quite a lot of tools, that will do it.
    ReStream, Bitrate viewer, DVD patcher, Easy changer(Darim encoder). Check the tool section.
  3. Thanks for that. ReStream did the job.
    Cheers,
    Bolix
