I've got a major prob!
I downloaded Black Hawk Down from KAzaa. And im trying to burn it as a VCD!
Its Avi wit 14 FPS!
I tried using TMPGenc, but hwen i try loading it it sayd its unsupportable!
I also tried Nero 5 but tat didnt work. Can any one give me a step by step instruction to do this! thanks!
Can you open it and view it on your PC at all??
Do you know who it is by? -
First off answer the questions that MaDmiZe asked and then we can help more.
Did you adjust he direct show vfpi plugin on tmpgenc?
For future refrence try downloading a dvd rip of a movie.
At 14 fps it sounds like its a cam or taped screen.
Here use this for a step by step guide http://www.vcdhelp.com/divxtovcd.htm. I use nero instead of vcd easy
It is the first guide under convert (on left of screen)
Let me know If I can help more
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked?
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
