I've noticed that most downloaded movies from kazaa seem to be in .avi format. Is this the preferred digital format? Most that I have downloaded have been great quality and small enough to fit on a single CD.
I do have one that is 730 mb is there any way to get it smaller so that it will fit on a single cd or split it in half and put it on two CDs
Can I get some opinions on what digital video formats people prefer.
Then you saidMost that I have downloaded have been great quality and small enough to fit on a single CD.
You also wroteI do have one that is 730 mb is there any way to get it smaller so that it will fit on a single cd or split it in half and put it on two CDs
QUESTION>Can I get some opinions on what digital video formats people prefer
ANSWER> I perfer avi with a high bitrate so I can make the best possible vcd or svcd
Hope this helps
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
We are of course assuming that you want to end up with a VCD compatable mpeg1 type video, so that you at least have a chance of viewing it on a stand alone DVD player??
If Not then AVi is fine...for storage or to view on PC.But it has to be reencoded (basicly converted) to mpeg1 for use otherwise.
I don't know why people post only AVI's...all my stuff I put up in VCD format with descent quality and about the same file size( sometimes smaller).....The difference is that mine can burnt as is....all the others have to be redone for further use> -
thanks VCD4ME
O.K. Let me see if I have this straight. You can take a DVD create a avi file which is small then make it even smaller using DIVX? Or is DIVX and AVI the same thing? -
councilman,
You got it right but don't forget that an avi file can really be any size its just a file type.MaDmiZe is right divx is a codec which is an avi file.
A dvd can be ripped onto a hard drive uncompressed at anything upto 9.4gigs ,which of course is all the space on a dual layer dvd (store bought movie).
Hope this helps
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
