Hi there !
I´m trying to capture some music videos with my msi gforce 3 ti200.
can any one tell me witch program i can use with my gforce card.
i keep getting this failure notice (Cant detect capture device)
Results 1 to 12 of 12
Best Regards Cmanx DK
if you're getting the "can't detect capture device" error you probably didn't install the "nvidia capture drivers" from the driver CD that came with the video card.
Intervideo's Wincoder that came bundled with your card works ok (MPEG1, MPEG2), I prefere V-Dub"Peace through superior firepower" -
Okay i installed the drivers from the cd, but i think they are pretty old.
i mstill get the message.
If i look in the device manager, i have got the legacy video capture drivers.
But thank U! i´ll try capturing vith the vdub guide later.
Rock on !Best Regards Cmanx DK -
Hmmm, in device manager under "sound, video and game controllers" my disk loaded the "nVidia WDM video capture (universal)" drivers. Maby getting the WDM drivers will help.
I don't know where to tell you to get them, I looked on MSI's site with no luck. I could just be blind"Peace through superior firepower" -
if your using vdub as your capturing program then you will need the vfw wdm wrapper http://faq.arstechnica.com/link.php?i=714
if you have the wdm drivers for your card, vdub will not recognise them because it only recognises vfw drivers. this wrapper adapts the drivers so that they can be used in a vfw based program -
Okay Now its working i installed wdm and the wrapper !
Thank u for paitience with a newbie like me.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
