I downloaded this and the avi file is awesome. Now I want to encode it TMPEnc and not sure how to set the source with this format. The "what is" section doesn't reference 640x272? Should I go with vcd or svcd?
Go with SVCD. If sound goes out of sync, you might want to rip the sound to a wav file using VirtualDub then use TMPnc. I do this as a standard proceedure so I don't waste encoding time. Only takes a few minutes and it seems to take care of sound sync problems. Be sure to use the film template so the frame rate stays at 23.976. If you change the frame rate then the sound won't be in sync and then you have to strech or shorten the sound wav file accordingly.
I get a lot of movies like this - HQ DivX stuff ...
if your machine can handle it you should do xSVCD two pass VBR (use a bitrate calculator to set your bitrates)
set source to 1:1 VGA - Full Screen (Keep Aspect Ratio)
output aspect ratio 4:3 and DONT change the frame rate
I usually go with 352x240 resolution but thats your choice you can do 352x480 or 480x480 if you wish
export the audio in VirtualDub and use tooLAME with TMPGEnc to do the sound
you will end up with a VCD thats as good as the original source .... all this is IF your DVD will play non-standard SVCD's (xSVCD) -
Great! Thanks for the help! I'll try the xsvcd format. I've gott an APEX 800 and has handled everything so far plus the player section indicates it can handle it.
Can't wait to watch this one!
Rich -
FYI,
Thank you both! Just completed a test. I did as suggested and it is awesome! I converted audio to wav and used it with the video. Didn't do 2 pass VBR as TMPEnc estimated over 33 hours. That's with an AMD 1.3 and 512 of RAM. Just used NTSC film template for SVCD @480x480.
Thanks Again!!!!! -
Glad to help
I guess I should have told you that 2-Pass VBR can take a long time ... It's a good 11 hours for me on a PIII 256meg ram
but I love the results too much do it any other way -- I just start it at night before I go to bed - then when I get home from work the next day the movie is ready
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 03:19 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 13:27 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 19:56 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 11:41 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 17:49
